OBS Crashing on Startup and I need help
Is crashing on a filter. You should check what you added as filter and probably remove it.
Go to %appdata%\obs-studio\basic and temperally move or change the name of scene folder. Now start OBS to see if this helps. Of course, if it still crash, remove any plugin you have added.
