Yep. Confirmed for me. This plugin is segmentation faulting my OBS. I have deleted and clean rebuilt from source code each plugin that I have, which is 3: OBS-ndi source, rtsp-server, and audio-monitor. This is crashing me, bros. Linux Mint 64bit 20.2 Xfce. See linked thread in quotes for log file.Last time I build this plugin from source code to Linux it broke OBS. Please tell me how to install it? I installed it from instructions last time. I broke OBS and been painfully installing plugins one at a time and found out it was this plugin that caused it to segmentation fault.
Thread isn't approved yet so if you can't view it yet this is the heads up about it.Building from Source on Linux Mint 20.2 Xfce 64bit, segmentation fault after running
Hi, I just learned to build OBS Studio from github and been using it for a couple of days now. I use it to dual stream to my friend across a network. His Desktop to me, and my desktop to him. We use NDI-Plugin, which he is on Windows 10, and I am on Mint. This did work for a week or more. Things...obsproject.com
info: [Audio Monitor] loaded version 0.7.1
Segmentation fault (core dumped)
Edit:Hi,
Is there any way to use a midi device to directly control the separate monitor/output channel volume controls ?
say, a Nanocontrol 2.
- show muted output in gray color
- add option to switch all tracks
- add custom slider color
- fix potential crashes
