Audio Monitor
Audio Monitor 0.8.3
maidstein
Hi Exeldro!
Thanks for you quick support! You're doing a great job!
But there are still some bugs:
  1. Volume jump in the audio mixer as Monsteer figured out.
  2. Volume configuration and locking in audio mixer dosen't correspond to volume configuration in filter menu.
And I still have a wish:
  • Latency control for each audio monitor.
Thank you for your efforts!
Maestro
Hey, maybe I got this wrong... But this plugin should allow me to switch audio device output for sources? My OBS is using default audio card 1. Can I use this plugin to output some sources to a audio card 2?
maidstein
I am not sure if I understand you correctly. But you can transfer audio signals from one sound card to another sound card with OBS and the plug-in Audio Monitor.
If you want to split or forward an audio signal to another software I'd rather recommend a virtual audio cable. For example there is VB-Audio Cable for free. You can have multiple of them. You also can combine virtual audio cable with this plugin in OBS like I do it.
Maestro
@maidstein I have 2 physical audio cards, so I don't think I need virtual audio cable. I'm looking for a solution to make OBS keep sending sound to audio card #1, but send sound from one browser souce in OBS to audio card #2. I tried "Aduio Monitor" filter from this plugin, it doesn't switch audio device for me.
maidstein
If you want to monitor audio from one source to two different audio devices, you have to add the filter 'Audio Monitor' twice. - Doesn't work?
Maestro
I need to monitor souce only from audio card #2. "Audio Monitor" filter doesn't do anything at all for me.
Maestro
@maidstein
Anyone having the same issue I am -- the Audio Monitor feature does not appear in the Filters tool...
  • I manually placed the .dll and .pdb files in the right location.
  • When that did not work, I even ran the installer program.
  • I closed and restarted OBS each time I tried something.
Any ideas?
excuses
I also wasn't seeing it in my Filters (v0.2.2, first time I installed it), both with the installer and manually extracted. I was using OBS 26.0.2, but I just upgraded to 26.1.1 and it's working now (Win10 x64).
Here's what my log was saying when it wasn't loading in 26.0.2:
21:17:23.538: Module '../../obs-plugins/64bit/audio-monitor.dll' not loaded 21:17:23.590: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
