Hi, actually i'm making tha same thing. using ffmpeg and v4l2loopback, and finally OBS. the solution I adopt is:
first step, raspberry: capture cam (dev/video0) in mjpeg format and trasmit to raspberry own IP, via TCP connection:
ffmpeg -f v4l2 -input_format mjpeg -video_size 1920x1080 -framerate 25 -i /dev/video0 -c:v copy -f mjpeg tcp://192.168.2.109:8080?listen
second step, PC, laptop: receive TCP flow, from raspberry IP, decode mjpeg to rawvideo and put the video in a v4l2loopback virtual device (dev/video0):
ffmpeg -f mjpeg -c:v mjpeg_cuvid -r 25 -i tcp://192.168.2.109:8080 -f v4l2 -pix_fmt yuv420p /dev/video0
third step: open OBS anc add a v4l2 device, select /dev/video0 (or whatever is your video loopback), you'll find your streamed video.
after a lot of research and experiments I find is best to manage the streaming part outside OBS, and leave OBS to only capture a video device.
note that from capturing USB to OBS signal is never converted, and quality is at its best. you have only to decode mjpeg to raw before sending to video loopback device. this is esaly done with mjpeg decoder in ffmpeg which can be software (mjpeg) or hardware accelerated (mjpeg_cuvid for Nvidia or mjpeg_qsv for Intel).
hope it helps. if you have others ideas, please let me know.
Bye!!
