Rodecaster Pro 2 Duel PC Stream Setup Help?
Trunkz
Nobody on youtube has a setup for this using Elgato 4K60 Mk2 Capture Card and then OBS to Stream on Twitch.
I'm having problems from mic hiss, then no mic hiss but double sounds, just one problem solved only for another to appear...
I'm hoping someone out there has theirs set up and can post the settings they use for both OBS and the RP2 itself (outputs, etc).
