Question / Help OBS Game Capture stuttering and rubber band. Low CPU usage, no dropped frames.
Any solution to this? I've been trying to fix obs game recording stutter for ages! Warzone is a pain in the ass
Warzone has been a problem for me for ages.
Possibly I came across something that helped with, however.
I always use OBS as an admin, have GameMode on, limit the FPS and try everything once ...
I also tested the hardware accelerated GPU scheduling, since I use several monitors anyway, one of which is set to 120 Hz and the rest can only be 60 Hz.
Always had laggs with Warzone.
I tested it again today and came across that OBS does not recognize that I have switched it on.
The LOG says that it is OFF.
Then I wanted to look at the entry with regedit (HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ GraphicsDrivers) and saw that there was NO (!!!) DWORD file for it.
That was missing ...
I then created one with the name "HwSchMode" and entered 2 for Value Data.
After that, OBS recognized it and then it was really on.
I've just tested it for a round of Warzone and it looks smoother than before.
So now I've switched on GameMode and Hardware Scheduling.
I didn't notice it before because I switched it on in Windows but didn't pay attention to whether it was recognized in OBS.
It may also help one of you.
I used Google translate.
Try minimizing obs while recording. For some odd reason it worked for me when my minecraft gameplay was stuttering.
