Question / Help I need help with stuttering and lags
Idkwthisgoinon
So at first i wanted to start streaming got obs and tried to stream the video was stuttering can't really explain it it would skip like a couple a frames load a frame skip load and continue like that and i thought it was my network that was pretty bad lowered everything the lag wouldnt stop so i decided to try to record a video i recorded it and saw the same skip frames load skip load pattern is it anything to do with my setttings or anything to do with my specs network??
I have a radeon rx 570 i5 6400 2.70GHz Overclocked to 3.00GHz 16GB RAM i got an ssd 120gb aswell network download 50mbps upload 5mbps
Keep in mind it was 60FPS ingame and obs showed it was filming in 60fps this is what i mean https://www.youtube.com/watch?v=2dt-1MTPikQ&feature=youtu.be
Idkwthisgoinon
07:04:46.918: CPU Name: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
07:04:46.918: CPU Speed: 3061MHz
07:04:46.919: Physical Cores: 4, Logical Cores: 4
07:04:46.919: Physical Memory: 12240MB Total, 6915MB Free
07:04:46.919: Windows Version: 10.0 Build 17134 (revision: 112; 64-bit)
07:04:46.919: Running as administrator: false
07:04:46.919: Aero is Enabled (Aero is always on for windows 8 and above)
07:04:46.919: Windows 10 Gaming Features:
07:04:46.919: Game DVR: On
07:04:46.920: Sec. Software Status:
07:04:46.921: Avast Antivirus: enabled (AV)
07:04:46.922: Windows Defender Antivirus: disabled (AV)
07:04:46.922: Windows Firewall: enabled (FW)
07:04:46.922: Windows Defender Antivirus: disabled (ASW)
07:04:46.922: Avast Antivirus: enabled (ASW)
07:04:46.923: Portable mode: false
07:04:47.020: OBS 21.1.2 (64bit, windows)
07:04:47.020: ---------------------------------
07:04:47.033: ---------------------------------
07:04:47.033: audio settings reset:
07:04:47.033: samples per sec: 44100
07:04:47.033: speakers: 2
07:04:47.034: ---------------------------------
07:04:47.034: Initializing D3D11...
07:04:47.034: Available Video Adapters:
07:04:47.036: Adapter 1: Radeon RX 570 Series
07:04:47.036: Dedicated VRAM: 4237361152
07:04:47.036: Shared VRAM: 2122641408
07:04:47.036: output 1: pos={0, 0}, size={1920, 1080}, attached=true
07:04:47.038: Loading up D3D11 on adapter Radeon RX 570 Series (0)
07:04:47.059: D3D11 loaded successfully, feature level used: 45056
07:04:47.807: ---------------------------------
07:04:47.807: video settings reset:
07:04:47.807: base resolution: 1920x1080
07:04:47.807: output resolution: 1280x720
07:04:47.807: downscale filter: Lanczos
07:04:47.807: fps: 40/1
07:04:47.807: format: NV12
07:04:47.807: YUV mode: 601/Partial
07:04:47.809: Audio monitoring device:
07:04:47.809: name: Speakers (Realtek High Definition Audio)
07:04:47.809: id: {0.0.0.00000000}.{adcda0c7-2736-4570-be20-ac83628d3766}
07:04:47.809: ---------------------------------
07:04:47.812: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
07:04:47.814: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
07:04:48.113: [AMF] Version 2.3.3 loaded (Compiled: 1.4.7.0, Runtime: 1.4.7.0, Library: 1;4;7;0;18.10;201805161434;CL#1555789).
07:04:48.286: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
07:04:48.286: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
07:04:48.286: (127)
07:04:48.286: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
07:04:48.287: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
07:04:48.289: [browser_source: 'Version: 1.31.0']
07:04:48.293: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
07:04:48.293: (126)
07:04:48.423: Couldn't find VLC installation, VLC video source disabled
07:04:48.426: No blackmagic support
07:04:48.432: ---------------------------------
07:04:48.432: Loaded Modules:
07:04:48.432: win-wasapi.dll
07:04:48.432: win-mf.dll
07:04:48.432: win-dshow.dll
07:04:48.432: win-decklink.dll
07:04:48.432: win-capture.dll
07:04:48.432: vlc-video.dll
07:04:48.432: text-freetype2.dll
07:04:48.432: rtmp-services.dll
07:04:48.432: obs-x264.dll
07:04:48.432: obs-vst.dll
07:04:48.432: obs-transitions.dll
07:04:48.432: obs-text.dll
07:04:48.432: obs-qsv11.dll
07:04:48.432: obs-outputs.dll
07:04:48.432: obs-filters.dll
07:04:48.432: obs-ffmpeg.dll
07:04:48.432: obs-browser.dll
07:04:48.432: image-source.dll
07:04:48.432: frontend-tools.dll
07:04:48.432: enc-amf.dll
07:04:48.432: coreaudio-encoder.dll
07:04:48.432: ==== Startup complete ===============================================
07:04:48.436: All scene data cleared
07:04:48.436: ------------------------------------------------
07:04:48.478: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
07:04:48.521: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
07:04:48.529: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
07:04:48.905: Switched to scene 'Game'
07:04:48.905: ------------------------------------------------
07:04:48.905: Loaded scenes:
07:04:48.905: - scene 'Game':
07:04:48.905: - source: 'Game Capture' (game_capture)
07:04:48.905: - scene 'Desktop':
07:04:48.905: - source: 'Display Capture' (monitor_capture)
07:04:48.905: - scene 'Scene 2':
07:04:48.905: - source: 'Game Capture 2' (game_capture)
07:04:48.910: [game-capture: 'Game Capture'] attempting to hook process: FortniteClient-Win64-Shipping.exe
07:04:48.935: [game-capture: 'Game Capture'] shared texture capture successful
07:04:54.234: [game-capture: 'Game Capture'] capture stopped
07:04:54.237: [game-capture: 'Game Capture'] attempting to hook process: FortniteClient-Win64-Shipping.exe
07:04:54.259: [game-capture: 'Game Capture'] capture stopped
07:04:56.259: [game-capture: 'Game Capture'] attempting to hook process: FortniteClient-Win64-Shipping.exe
07:04:56.284: [game-capture: 'Game Capture'] capture stopped
07:04:58.284: [game-capture: 'Game Capture'] attempting to hook process: FortniteClient-Win64-Shipping.exe
07:04:58.309: [game-capture: 'Game Capture'] shared texture capture successful
07:05:19.234: [game-capture: 'Game Capture'] capture stopped
07:05:20.435: [game-capture: 'Game Capture'] attempting to hook process: FortniteClient-Win64-Shipping.exe
07:05:20.459: [game-capture: 'Game Capture'] shared texture capture successful
07:05:23.017: ---------------------------------
07:05:23.017: [x264 encoder: 'streaming_h264'] preset: slow
07:05:23.017: [x264 encoder: 'streaming_h264'] profile: high
07:05:23.017: [x264 encoder: 'streaming_h264'] settings:
07:05:23.017: rate_control: CBR
07:05:23.017: bitrate: 6000
07:05:23.017: buffer size: 6000
07:05:23.017: crf: 0
07:05:23.017: fps_num: 40
07:05:23.017: fps_den: 1
07:05:23.017: width: 1280
07:05:23.017: height: 720
07:05:23.017: keyint: 80
07:05:23.017:
07:05:23.017: [x264 encoder: 'streaming_h264'] custom settings: 4.1 scenecut=0
07:05:23.022: ---------------------------------
07:05:23.023: [FFmpeg aac encoder: 'Track1'] bitrate: 128, channels: 2, channel_layout: 3
07:05:23.023:
07:05:23.730: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-vie.twitch.tv/app...
07:05:23.783: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GbE Family Controller (ethernet, 1000 mbps)
07:05:25.317: [rtmp stream: 'adv_stream'] Connection to rtmp://live-vie.twitch.tv/app successful
07:05:25.320: ==== Streaming Start ===============================================
07:06:49.877: [rtmp stream: 'adv_stream'] User stopped the stream
07:06:49.877: Output 'adv_stream': stopping
07:06:49.877: Output 'adv_stream': Total frames output: 303 (3212 attempted)
07:06:49.877: Output 'adv_stream': Total drawn frames: 3453 (3474 attempted)
07:06:49.877: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 21 (0.6%)
07:06:49.877: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 2909 (90.6%)
07:06:49.878: [rtmp stream: 'adv_stream'] Freeing 24 remaining packets
07:06:49.880: ==== Streaming Stop ================================================
07:06:50.225: Video stopped, number of skipped frames due to encoding lag: 1881/3348 (56.2%)
07:08:47.049: ---------------------------------
07:08:47.049: [x264 encoder: 'streaming_h264'] preset: slow
07:08:47.049: [x264 encoder: 'streaming_h264'] profile: high
07:08:47.049: [x264 encoder: 'streaming_h264'] settings:
07:08:47.049: rate_control: CBR
07:08:47.049: bitrate: 6000
07:08:47.049: buffer size: 6000
07:08:47.049: crf: 0
07:08:47.049: fps_num: 40
07:08:47.049: fps_den: 1
07:08:47.049: width: 1280
07:08:47.049: height: 720
07:08:47.049: keyint: 80
07:08:47.049:
07:08:47.049: [x264 encoder: 'streaming_h264'] custom settings: 4.1 scenecut=0
07:08:47.054: ---------------------------------
07:08:47.054: [FFmpeg aac encoder: 'Track1'] bitrate: 128, channels: 2, channel_layout: 3
07:08:47.054:
07:08:47.065: ==== Recording Start ===============================================
07:08:47.065: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/Connector/Videos/2018-06-14 07-08-47.mp4'...
07:10:43.764: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/Connector/Videos/2018-06-14 07-08-47.mp4' stopped
07:10:43.764: Output 'adv_file_output': stopping
07:10:43.764: Output 'adv_file_output': Total frames output: 4331
07:10:43.764: Output 'adv_file_output': Total drawn frames: 4648 (4668 attempted)
07:10:43.764: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 20 (0.4%)
07:10:43.764: ==== Recording Stop ================================================
07:10:44.779: Video stopped, number of skipped frames due to encoding lag: 3358/4515 (74.4%)
07:18:05.337: [game-capture: 'Game Capture'] capture window no longer exists, terminating capture
07:18:05.342: [game-capture: 'Game Capture'] capture stopped
07:21:59.204: Switched to Preview/Program mode
07:21:59.204: ------------------------------------------------
07:22:02.979: Switched to scene 'Game'
07:22:02.980: Switched to regular Preview mode
07:22:02.980: ------------------------------------------------
the log i forgot to include
How come you are encoding at 40FPS? Is there a special reason for this? Also instead of X264 you could alleviate a lot of the pressure on your CPU you could use the AMD AMF Encoder. This will put the encoding responsibility on the Video Card encoder instead. If you use X264 the last poster is right, your CPU and many cannot handle Slow Preset. You should use Veryfast and possibly faster, but I'd probably try Veryfast and see if that is to your liking. Also try the AMF AMD Encoder and see if that is to your liking, if it is, then stick with that because that will allow your CPU to deal with the content you are recording rather than that plus encoding it, allow the GPU to do it and take a significantly smaller to no performance hit. But of course to each his own and your mileage may vary. Myself, I have an i7 but I use the AMD AMF Encoder, I prefer it. The quality is not quite as good as X264, but I'd rather have the zero impact while I'm trying to stream and play 1080P Ultra at 60FPS and streaming it at the same 1080P/60FPS, otherwise I'd be dealing with missed render frames, missed encodes, and the drag on my system while playing AAA games. Anyway give it a try if you like and let us know how it goes. :)
EDIT: (README!) I just noticed you have your bitrate set to 6000, but you mention you have a 5Mbps upload, this is why all of your frames are DROPPING at the NETWORK, not an encoding issue, although I would still use AMF/AMD instead so your CPU doesn't have to work so hard. Anyway, 6000 is 6Mbps, exceeding your 5Mbps connection. You need to start at 4Mbps (4000) and see if it can hang, if not, reduce it by 250 every time until it does. That way you have a little headroom for other devices to use the connection and not cause major dropouts on your stream.
My recommendation to try out is: 60FPS Output not 40, Set the Encoder to use AMD AMF Encoder, set for CBR @ 4000 and let it rock. See how that goes and let us know.
SPIKEYPUP/Patrick Ewalt
