Question / Help Does anybody know how to fix the Stopping Recording without using just one audio track?
byTh3Loc
The Stopping Recording Bug is caused by using more than one audio track but I need two audio tracks.
So does anybody know how to fix it with two audio tracks or is there a update comming?
carlmmii
Don't record directly to .mp4. There are several issues doing that, the most severe being the file not being readable if anything happens during recording, since it has to be closed with necessary metadata about the file at the very end (which could be where things are failing on your end).
Record to .mkv. If you need .mp4 for further editing, just use the Remux tool in OBS -- it's very fast, and you can delete the .mkv once the .mp4 is created.
byTh3Loc
Thank you going to try that.
