Recording stuck at one frame but audio still plays
The log you provided shows no attempt to record.
And the streamelements plugin you installed adds enough useless "info" level messages to the log that it makes it difficult to troubleshoot.
Thanks for answering! Could you suggest me what I should do? How can I get the correct log file?
Also can I fix the recording or is it completely broken now?
To cleanly remove the OBS.live plugin:
  1. Uninstall OBS.Live
  2. Uninstall OBS Studio (make sure that "User Settings" is not selected)
  3. Install OBS Studio again from https://obsproject.com/
    Your settings will be saved unless you have selected to delete them during removal.
Then do an attempt at recording, then upload a current log after doing that attempt and provide a link.
