No audio recorded with Virtual Cable and USB Microphone
DevSprout
Hi everyone, I'm new to the forum so I apologize in advance if I'm breaking any rule or posting in the wrong place.
These days I've been going crazy trying to record both video and audio through OBS. This is what I've done currently:
  1. Set up filters on my mic on OBS (HyperX Solocast). The filters are: NVIDIA Audio Effects for noise removal, Gain, 3-band Equaliser, Expander, Compressor, Limiter and Audio Monitor set to Default. (for this one I installed an external plugin called Audio Monitor)
  2. I installed Virtual Cable (just the basic installation with one cable only), went into OBS Settings > Audio > Monitoring Device: CABLE Input (VB-Audio Virtual Cable)
  3. I went then on Windows Sound Settings > More sound settings > Recording > Cable Output > and toggled "Listen to this device". This option is untoggled on the Solocast mic
  4. I then installed the OBS plugin DroidCam OBS. Installed DroidCam on the phone as well and set it up via USB successfully. I can see what the camera sees in OBS and actually record it.
  5. I added a new source called "Audio Input Capture" and set it to Mic/Aux. Tried recording and what I get is video only. Switched the source to "Cable Output (VB-Audio Virtual Cable). Tried recording again with no results.
I don't know what to try anymore. In the OBS mixer I doo see the volume moving when talking into the mic. Both for the Mic/Aux volume and for the Audio Input Capture when present. Specifically, when Audio Input Capture is presente as a source I do see volume moving both it's on Mic/Aux or Virtual Cable.
On "Advanced Audio Properties" I have everything set on monitor off except for Mic/Aux that is on "Monitor and Output".
When recording, I have to mute my laptop volume otherwise I'll be hearing to myself from the speakers and it creates a loop between audio played from from laptop entering the mic.
As a test, when going to Audacity > Edit > Preferences > Audion Settings > Recording and setting device to CABLE Output (VB-Audio Virtual Cable) and recording a track, it correctly records the mic audio with all OBS filters applied (OBS need to be running of course).
Does anyone have experience with this?
This is my first time ever dealing with recording and OBS so I'm trying to learn and I probably did something wrong.
