Need help, Framerate issues with 75hz screen and 60fps stream
Anguxilion
My issue is pretty simple, I have a 75hz screen, and when I'm playing Valorant, it runs at 75fps, the default stream output is 60fps, and here starts the trouble.
it looks stuttery on Twitch, I can choose to stream at 75fps on OBS, and it looks good on my 75hz screen, but if I see the gameplay on any other screen with refresh rates that are divisible by 30 (30/60/120/180/etc) it looks pretty bad again.
I tried to play at 60fps and stream at 60fps and it looks good on most devices, but It's annoying having to play at a lower refresh rate, it doesn't feel smooth enough during my gameplay. so, my question is:
is there any way to "smoothen" the stream fps to make them look better on 60hz screens? Is there any plugin to do it? any special config? or do I just have to accept the fact that it is what it is? I know that getting a 120hz screen would help because of the frame pacing but that won't happen soon
I can still play at 75 and stream at 60, but If there's any way to improve the experience I'm giving without ruining my own experience playing or wasting too much money, I'll do it
Standard, run it @ 60HZ when using OBS.
Okay, I found out that playing without any kind of fps cap (game native cap, nvida cap nor vsync), so it runs above 300fps and playing on borderless window (forces desktop vsync) I have a smooth experience on my gameplay and it obs has enough frames to make it smooth on 60fps (there are some slowdowns here and there but it's definitely smoother than before)
