Minecraft shaders causing performance issues when using OBS
Tylarosquinnos
Hi, I need some help with Minecraft shaders and OBS.
I'm trying to record Minecraft Java with OBS while using Photon Shaders, but I'm not sure which settings I should use to keep the game running smoothly while recording.
I'm using this version of Photon Shaders:
https://bravith.com/shaders/photon-shaders/
Does anyone here use OBS with Photon Shaders? I'm mainly wondering if there are any OBS or shader settings that can help reduce the FPS drop while recording.
Thanks!
