Question / Help input lag when streaming HELP!
StaySideWaysYT
So basically when i stream fortnite, i feel a little more input lag, then when im not streaming and i dont know why. PLEASE HELP!!
my specs are
ryzen 5 2600
gtx 1660 xc ultra
16gb ddr4 2600 mhz ram
gigabyte b450m
120gb ssd
1tb hard drive
500w power supply
my obs settings are
nvenc (new)
6000 bit rate
max quality
cbr
profile high
look ahead off
psycho visual tuning on
GPU 0
max b frames 2
my fortnite settings are
view distance low
shadows off
anti aliasing off
textures low
effects low
post processing low
v sync off
motion blur off
multi threaded rendering on
1080p
full screen
frame limit unlimited
Sukiyucky
Dont play with unlimited frame limit. Cap the frame rate to be your monitor refresh rate.
If you have a 60Hz, set frame limit to 60FPS
If you have a 144Hz, set frame limit to 144FPS
If you have a 240Hz, set frame limit to 240FPS
There is no point in having your computer generate more frames than what your monitor can grab from video frame buffer. Its wasted work that is ignored and puts strain on your system.
StaySideWaysYT
ok so basically i fixed the issue. i went into bios and set a xmp profile and overlocked my ram from 2400 MHz to 3000MHz, and now i dont feel the input lag i was feeling! thanks for the help anyways!
