Framedrops and Low Bitrate Despite Fast Connection
Owltamer
https://obsproject.com/logs/qDT9df6XVbDwTOgG
Here is my stream log from a test. I don't know when this problem started given I was using some offline streams as a resource for recording, but I realized just recently that they look absolutely horrible, and when I tried to figure out why I saw that the bitrate was only hitting like 2k max and dipping really low very often, with MOST frames dropped. A speedtest supposedly says my upload and download are really fast, and packet loss tests come back with 0% loss, so I have no idea what's causing this.
I have tried a few different things, such as changing what site I am streaming to (happens on Youtube and Twitch), trying both OBS and Streamlabs (same issue on both, so that kinda rules out my OBS just not being updated given its the latest Streamlabs), I've changed the bitrate around (between 10k and 6k, but no matter what the end result is bitrate fluctuating between 0 and 2k), changing the Encoder Preset to the highest, lowest, and in the middle (no difference), running as Administartor, adding both programs to the firewalls allowed programs, but nothing has changed anything.
Thank you for any help <3
