Dumb audio question. Help appreciated :)
Cody.Tibbitts
Hey guys!
Quick and to the point:
-- https://youtu.be/uRUOaI-Ca4Y link to a shortened unlisted video with the issue.
-- The log file is attached below.
I can do the basics with audio.... any issue that pops up, I won't have a resolution for. So, apologies for a potentially dumb question.
Initially, we were having "crackling" audio issues 3/10 times when going live. A simple restart of the computer fixes that issue. When I monitor audio inside of OBS I actually don't hear the crackling but on the live stream, I hear it.
Yesterday when recording a class... the issue appeared for the first time on a recording.
We have this issue on multiple computers that are usually reliable.
We've tried changing mixers. Uninstalling & reinstalling OBS in case of hidden audio sources and to "start fresh". Any help or guidance with this would really be appreciated.
  • 2023-05-18 14-16-06.txt
deFrisselle
Your hardware is a bit on the weak side Run OBS as Admin
It also seems that the issue is audio clipping along with buffering issues due to hardware
Cody.Tibbitts
Thank you for confirming that! We'll upgrade.
