Serious_Hitman
Hello, I recently built a second computer for streaming and I started to have problems with audio sync inside OBS. The wierdest thing is that the problem shows up only after 1~2 hrs of streaming. Before that, I also used capture cards on my main computer and everything was fine. Going back to single PC setup is not an option. Well... unless of course this problem finally drives me crazy.
I have 3 different capture cards in my system:
Elgato 4k Pro
AverMedia Live Gamer II
AverMedia c127 gamecaster (didn't used it yet)
2 cards (Elgato 4k and AVM LGII) have these problems.
Clicking "Deactivate" and then "Activate" button fixes the audio. But cmon, shutting down gameplay every hour just to get audio fixed is not a solution, its just bad and like i said, i don't have this issue at all on my main PC.
I also found out if i change buffering mode from "auto-detect" or "enabled" to "disabled" fixes the audio. So i figured may be that was the problem i decided to disable the buffering - audio still desyncs, funny part is that now if i want to fix it i have to ENABLE and then disable the buffering. Both options will cause image to freeze for a few seconds, so no, this is not a solution either.
Streaming PC specs:
AMD Ryzen 1700
ASUS Prime x370 - PRO
NVIDIA GTX 970
16 Gb Ram
Main PC specs (PC that does not have this issue)
intel i9 9900K
ASUS ROG Strix z390-f
RTX 2080 ti
32 Gb of Ram
What i have already tried:
Changing encoder presets medium, fast etc.
Changing encoder from x264 to NVENC
Switching 41hz to 48hz in OBS
Updating Audio/Chipset/GPU/Capture Card Drivers
Updating and Loading Optimized Defaults in BIOS
Attached the log file from last time it happend.
I appreciate any suggestions to solve the problem.
Elgato 4k Pro
Streaming PC specs:
AMD Ryzen 1700
NVIDIA GTX 970
16 Gb Ram
intel i9 9900K
RTX 2080 ti
32 Gb of Ram
