BSOD after I stream for like 5-30 Minutes using OBS!
ZapDaStreamer
Hello Guys, I just wanted to try to stream with my new PC setup but then i ran into a lot of BSOD's :(
These BSOD's only happen, if I stream tho, after like 5-30 minutes I hope anyone can help me...
The crash dump report:
On Sun 11.10.2020 15:56:58 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\101120-10156-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F3EA0)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF800523FBDD7, 0xFFFFFD0A7622B408, 0xFFFFB380980E7920)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
My components:
Power Supply: Sharkoon Silent Storm Cool Zero, 850 Watt
Hard Disk: 1TB WD Blue
M2 SSD: 500GB Samsung 970 Evo
Mainboard: MSI MPG B550 Gaming Carbon WIFI
RAM: 4x 8GB (32GB) G.Skill Trident Z RGB, 3200 DIMM CL16
CPU: AMD Ryzen 9 3900X
Graphics Card: GIGABYTE GeForce GTX 1070 OC (Waiting for my 3080)
My setup:
First Monitor: Acer KG251QD, 240Hz
Second Monitro: Acer KG241, 75Hz
Third Monitor: Acer KG241, 75Hz
Webcam: Logitech HD Pro C920
Headset: Logitch G430
Keyboard: Razer Blackwidow Chroma V2
Mouse: Razer Deathadder V2
My OBS settings:
Bitrate: 6000 Kbps
Encoder: Software (x264) (also happens with Nvidia encoder)
Audiobitrate: 160
encoder settings: veryfast
What I have allready tried:
- updating all drivers with Windows Updates, GeForce Experience and Driverbooster 8
- reinstalling OBS
- Ram check with Windows memory diagnostic tool
- Prime 95 check
- In Bios, Ram and CPU clock on auto and on a stable value. (Ram tested with 3200 and 2333 MHz)
- GPU test with 3D Mark
- The last thing I have tried was, to reinstall Windows 10, nothing changed.
Please someone, help me T.T
My components:
My setup:
My OBS settings:
Bitrate: 6000 Kbps
Audiobitrate: 160
- reinstalling OBS
- Prime 95 check
Okay, Go into your programs and applications and uninstall MSI SDK, that should fix it for you. It is the Dragon Centre software causing the BSOD in obs, I just had the same problem.
