I've already figured out, that this is only an issue, while OBS is open. Whenever I close it, everything sounds perfectly fine.
When I open OBS tho, my Gamesound on my Nintendo Switch gets distorted and the pitch randomly goes up and down (kind of sounds like the sound sounds when you get hit by a lightning in Mario Kart 8 Deluxe, but a lot less, but still very noticeable).
What is the issue here?
On my old PC, it all worked perfectly fine. My old PC was Windows 10, my new one is Windows 11... Might that be an issue?
What can I do to stop it from distorting?
I have my OBS sample rate set to 48kHz, my capture card is set to "2 Channel, 16 bit, 48000 Hz (DVD-Quality", and I also can't change that. My normal headphones are set to the same sample rate.
I really need help, because I just can't record videos with audio issues like that, it sounds terrible.
