knopf55
Installed OBS two weeks ago, streamed live music events successfully (except sound quality) three times via Youtube live-streaming on my channel. Video looks great. The sound quality is so bad, it has to improve otherwise I have to try a different encoder.
Included: screenshots of all my settings in OBS, Mac system audio settings, and the midi setup interface. Also attached is an mkv file generated within OBS about 6 seconds long demonstrating the problem.
Echo is actually the wrong term for the problem, there is a delay on all external sound inputs — and some internal sources. The ONLY internal source that is clean of the delay is iTunes, I can play a sound file from there and stream it, and it’s clear of any echo. I have hooked up variations of external sources, like a USB mixer, also a Zoom H2n USB connected mic singly. All have delay in the audio. I have also tried the audio in the simplest format, that is the onboard computer speakers output, and onboard computer mic input. That also has the *@#& delay.
So to be clear, the effect I am calling a delay is this: If I snap my fingers near the microphone, I hear two snaps, the acoustic sound my fingers make outside of the earphones, and then a split second later my fingers snapping in the earphones. The stream recordings all have both sounds, hence the “echo” effect. Just discovered I cannot attach a video or audio file, so cannot demo the problem. Here is the link to one of the streams:
youtu.be
Also relevant, Soundflower does not update to high sierra, so I installed "IShowU" audio driver to aggregate the audio streams.
![youtu.be](https://i.ytimg.com/vi/kqoCUaAat38/maxresdefault.jpg)
Satsang Meditation with Live Music
Satsang Meditation begins at 23:40. Scheduled: 10-11 am Berlin Time. Jamie and Arpita stream a live music satsang meditation from the studio in New York, USA.
