Slight Lagging While Recording And A Slight Bit Of Crackling Audio And Laggy Audio
Cody&TylerSTUDIOS
Ok, So I Was Recording A Video For My YouTube Channel And Used OBS To Record The Video With Elgato HD60s And There's Still A Little Bit Of Lag With Crackling And Laggy Audio, Is There Any Way That I Can Fix This Issue?
OBS Log Here: OBS Log
1. The new Windows 10 Hardware-accelerated GPU scheduling ("HAGS") added with version 2004 is currently known to cause performance and capture issues with OBS, games and overlay tools. It's a new and experimental feature and we recommend disabling it via this screen or these instructions.
2. To ensure that OBS Studio has the hardware resources it needs for realtime streaming and recording, we recommend disabling the "Game DVR Background Recording" feature via these instructions.
3. One of your audio devices (Microphone (HD Pro Webcam C920)) has a sample rate (16 kHz) that doesn't match the rest (48 kHz). This can result in audio drift over time or sound distortion. Check your audio devices in Windows settings (both Playback and Recording) and ensure the Default Format (under Advanced) is consistent. 48000 Hz is recommended.
OBS Sample Rate: 48000 Hz
Speakers (Realtek High Definition Audio): 48000 Hz
Microphone (HD Pro Webcam C920): 16000 Hz
Game Capture HD60 S Audio (Game Capture HD60 S): 48000 Hz
4. Run OBS as Admin. Right click on shortcut, properties, advanced, check box, ok, apply, ok.
5. Your log contains no recording session. Results of this log analysis are limited. Please post a link to a clean log file.
To make a clean log file, please follow these steps:
1) Restart OBS as Admin.
2) Start your recording for at least 30 seconds. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc.
3) Stop your recording.
4) Select Help > Log Files > Upload Current Log File. Send that link here if still having issues.
