Starting about two weeks ago - after downloading the most recent version of OBS (0.26), I have started having audio problems where the microphone audio, or the ASIO Input audio has started crackling and making me sound like some kind of deranged robot.
The problem can only be heard at the viewer end of the stream, and seems to be caused by me doing too many things on my computer. Be it opening Chrome/A Game/Discord/iTunes/moving between scenes in OBS. But this has been no different to how I have operated for months. I’m not doing anything more or less than before.
I have also tried using Streamlabs OBS, believing the problem to be the newest OBS update (even though rolling back to a previous version does not resolve the problem), and while Streamlabs seemed to handle it for a while, it eventually succumbed to the same audio glitching. After which, I tried using X-Split, and that worked absolutely fine.
To make it even more strange, the EXACT same set up, works absolutely fine in RPAN Studio as well (Reddit’s version of OBS for RPAN). I get absolutely zero audio problems in RPAN, even if I am streaming on Twitch at the same time where I could be having audio problems.
The last stream that went perfectly fine happened on the Monday before I updated OBS, and have since been unable to stream without audio problems.
Example 1: https://www.twitch.tv/videos/840363150
Example 2: https://www.twitch.tv/videos/841485617
Example 3: https://www.twitch.tv/videos/841504668
The only way to resolve this issue at the moment is to restart OBS - not ideal during a livestream.
