OBS massive frame loss
grayhound
Hello! I've been streaming and after booting up Apex legends my OBS suddenly can't keep up anymore. It stutters VERY HEAVILY. My game looks totally fine, but OBS stutters down to like 10-20FPS. Apex uses 80-90% GPU which I believe is normal. OBS started using 50-60% GPU until I turned power management mode to max performance in nvidia control panel, now it uses like 30% which is still higher than it was (used to be like 10% while live) The only real difference is that I got a 1440P 170hz monitor and now suddenly it can't keep up. Would this be something I need to change in settings? I have my base resolution set to my monitor, and the output set to 1080P so that shouldn't be it.
Here are logs for reference if they help: https://obsproject.com/logs/LbVUis9ud91ZWvhH
Any and all help is appreciated, thank you.
I saw this but the issue is I never had this problem before. It seems to be happening for no reason. I even turned apex down to the lowest possible settings and with vsync and it didn't change anything even 1%.
