Question / Help Need Help Obs keeps crashing
FerretBomb
It appears this crash is being caused by the Tuna plugin. You may need to either remove it, or check for an updated version:
I remember that some versions (1.4.0) were causing crashes, but thought they'd been updated (1.4.1). You may just need to update to the latest version of Tuna.
dmangameing
Thank you very much for you help I will look for the update if cant find a update will remove
Once again thank you very much for you help have hope your day goes great
