calamarisundae
The 'monitor' part of 'monitor and output' in OBS is doing absolutely nothing for any of my audio-producing sources. I've been trouble shooting to no avail. Uninstalling things, reinstalling things. Rebooting. I have updated my copy of OBS to the latest version, updated my audio drivers, updated windows manually (the problem started prior to updating so I thought maybe updating would help) yet the problem persists. Everything is plugged in, turned on, updated, and functional. Except audio monitoring in OBS.
My setup, in brief, is a gaming laptop linked to an older pc via an hd60 S+ elgato. The laptop runs games very well but overheats if I try to run capture software simultaneously with the gaming. The old pc does the capturing to ease the burden on the laptop. The sound is working just fine independently of OBS in the elgatos 4k utility program. I can hear with my headset/nothing is wrong with it. In OBS the bars indicating the sound frequency are functional/output is working just fine. It's just that I cannot monitor ANY of the sound for ANY of my sources.
The only change I made was I stopped using Voicemeeter Banana. I originally started using it because my usb condenser mic sounded tinny/I was having regular audio issues with it. Voicemeeter Banana worked great at first but it started making my audio choppy and full of static instead of tinny. And nothing changed, I didn't interfere with the way I had it set up initially based off of Voicemeeter Banana tutorials so I don't know why it stopped working so well. I recently got a decent enough headset+mic so I thought I would axe voicemeeter and my cheap starter mic in favor of the new higher quality headset. My hyperX cloud headset works great outside of OBS so I don't understand what's going on.
My hardware appears to be fine and all of the software *ought* to be working. YouTube tutorials haven't been helpful. I haven't been able to find any helpful forum posts so far, having used several different search engines to look for advice. Someone on Reddit had the same problem I'm having now but a year ago and without any satisfactory fixes that I am aware of. I'm at my wits end here and would appreciate any help I can get for the matter
