Question / Help mic and desktop audio problem
Minner121
So I have a headset I connect to my pc and it has a mic
but when I go to record obs will only capture my mic audio or the desktop audio
what should I do to fix so it captures both??
Also when I go into obs and make sure my mic audio is set to the headset the desktop audio is cut off but then the mic audio works
and when the mic is working all audio from music to the games I'm playing is silent if the mic is working but if its not the desktop audio comes through
but after seeing my mic audio is working the only way for my regular music etc to come back I have to close obs but then my mic wont record in obs
what should I do??
