Hi, my issue is as follows. I have been able to connect on and off over time (been using for a month) but I'd say 75% of the time I cannot get a good stream going. When I hit preview stream everything looks fine, my stream is, my fps is >1000. When I am able to connect my stream is fine, my fps is >1000. But most of the time it just sits at 0.
I have uninstalled and reinstalled it repeatedly, sometimes that helps it work but usually only gives me 1 opportunity to stream. Then the 2nd time I try to stream it goes back to 0 fps.
Here is the last log comments - what can I do to fix this? I dont have older logs because I have been deleting the entire program and re-installing it to try to make it work.
19:17:55: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
19:17:55: Failed loading CUDA dll
