CodePixel
OBS can hear audio but I can't.
I can't get OBS to output audio to my monitoring device.
Recently ran in to an issue with monitoring browser source audio via OBS, Output works for stream but I can't hear on my end.
Make sure your audio devices are set up properly before trying this (bug?) fix.
Steps:
1. Make sure you turn monitoring off
2. Restart OBS
3. Enable Monitor Only (Monitor and Output)
This seems to be a temporary fix, sometimes it reverts back and I have to repeat the process again.
If you have a more permanent fix for this let me know, I hope this helps.
Not sure what triggers this issue, or how I can help on a fix for this because I checked the logs and startup monitoring devices and settings are the same as non bugged instance of OBS. (OBS 28.1.2)
Steps:
2. Restart OBS
