Continuing problems with VMWARE and OBS STUDIO 29.0.2 cut screen while recording and full screen
nicotek
Hi, I keep reporting the problem with OBS STUDIO 29.0.2 despite the updates the problem with VMWARE is still not solved, if I use "VMWARE" emulating Windows 10 or 11 with full screen and activate recording on Obs studio and configure it in window capture section with the capture method (Windows 10 1930 or higher) has the defect that it cuts the part where the taskbar is in the virtual section when recording, is there a way to fix this? This does not happen with the old version 27 of obs studio . I'm waiting patiently for some help or for it to be fixed, thanks regards
