Blueismyfavcolour
Hi all,
I have the same issue with OBS 26.1.2, Focusrite Scarlett 18i20 2nd Gen and M1 powered Mac Mini. I have enabled mic access and also full disk access for good measure but no dice. HOWEVER:
When I enabled 7.1 under audio settings, suddenly I can see all my inputs monitoring on the mixer. I don't want to stream in 7.1 for obvious reasons so this isn't a solution, but it prove that this seems to be some kind of bug. ie when eight output channels are selected, suddenly it decides to enable eight inputs and that allows the interface to be seen... or something.
I have the exact same issue.
Everything is set up fine.. I'm just getting no audio from my interface unless I have surround sound enabled in OBS. :S
