Audio activity in meter and monitors, but stream and recording are silent
koizilla
Running OBS 27.1.3, the audio works as expected in the Audio Mixer pane and through the monitor.
There is no audio, however, in recordings or output to my Twitch livestream.
The only audio source I'm trying to stream or record is set to Track 1 in:
  • Advanced Audio Properties
  • Settings > Output > Streaming
  • Settings > Output > Recording
I've tried several permutations of the options in Settings > Audio. Please view the attached screenshots for more. The attached logs cover the duration of the issue.
Thank you
  • 2021-10-07 19-11-37.txt
  • 2021-10-07 20-04-12.txt
koizilla
Mark "Track 1" in Advanced Audio Propertires for the audio sources you need to stream and record.
Pretty sure I already did that. Also specified that everything is set to Track 1 of the text in my original post. Unless what you're saying is different from the setting shown in this screenshot, also from my op?
