Trying to run a Nintendo Switch through a capture card in OBS, will not run above 720p.
DarthEwok
When I run my Switch through a capture card into OBS I am unable to set the resolution to 1920x1080, even though the capture card should be good up to 4k and the Switch docked is supposed to run at 1080p.
The capture card I am using is the Razer Ripsaw X.
Screenshot below. I can physically type a larger resolution into the resolution box, but then I just get a black screen (no audio either).
Not sure if this is an issue with the capture card, OBS, or if there's just a different menu somewhere I should be doing this under (I have the capture card in OBS as a 'Video Capture Device' under Sources, and then this is just the Properties menu from right-clicking on that).
Anyone know of any way to do this?
