Struggling with huge sound issue
uwu
Hi !
Everytime a constant sound is being played (like music for example) i get a regular tick (really high and almost painful) every like 5-10seconds especially with some more bassy/rythmic music. This happens only on stream and recordings i don't get that on my headphones. I use voicemeeter to isolate spotify audio but that about it, everything is raw and default and this PC is brand new.
List of the things i've tried :
- Messing with obs output and audio settings.
- Trying to sync sample rate between windows outputs, obs, and voicemeeter
- Removing all sources but the display capture and all audio channels but desktop audio
- Switching usb ports for all devices
- Messing with voicemeeter buffer settings
- Removing voicemeeter entirely and using basic inputs and settings
- Only using one monitor (yes i'm that desperate at this point)
I've been trying to fix it for a while and nothing seems to make sense i really don't know where it's coming from and it's extremely frustrating.
I can make a recording and upload it to youtube if you want to hear what it sounds like.
Thank you in advance for your answers.
uwu
More details
- Also messed with "use device timestamps" settings
I also get the same problem if i record with another software like twitch studio beta for example.
Clicking sound only heared on right side somehow.
Hope it helps.
