Dr.Scientist
For Days now I've been trying to find a solution as to why I keep finding this error in my log. The Error is named "Max Audio Buffering" under the critical tab once you analyze the log. The advice it gives is to check my CPU and close any background programs but those aren't the issues, and the last solution says its could be caused by "incorrect device timestamps" and I should restart OBS. It has started to affect my streams and would appreciate any advice on the matter. Thank You <3
