Bug Report Starting output fails when trying to stream. Have been streaming before with same settings for about 2 months now. First time encountering issue
slashio
Quick resume of the problem:
I have been streaming league of legends for about a pair of months now, havent changed any settings since I got it all going well. Got home from work last night and tried to start stream but this would appear in my screan;
i've honestly been looking for a solution in google and youtube but couldnt find anything usefull. I saw a few posts here and noticed they posted the log so I will too, in case it comes in handy.
Thanks in advanced for taking your time to read and helping me out!
12:37:26.171: CPU Name: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
12:37:26.172: CPU Speed: 3193MHz
12:37:26.172: Physical Cores: 4, Logical Cores: 4
12:37:26.172: Physical Memory: 8175MB Total, 3646MB Free
12:37:26.172: Windows Version: 10.0 Build 17134 (revision: 285; 64-bit)
12:37:26.172: Running as administrator: false
12:37:26.172: Aero is Enabled (Aero is always on for windows 8 and above)
12:37:26.172: Windows 10 Gaming Features:
12:37:26.172: Game DVR: On
12:37:26.359: Sec. Software Status:
12:37:26.404: Avast Antivirus: enabled (AV)
12:37:26.404: Windows Defender Antivirus: disabled (AV)
12:37:26.407: Windows Firewall: enabled (FW)
12:37:26.429: Windows Defender Antivirus: disabled (ASW)
12:37:26.429: Avast Antivirus: enabled (ASW)
12:37:26.478: Browser Hardware Acceleration: true
12:37:26.478: Portable mode: false
12:37:27.626: OBS 22.0.2 (64-bit, windows)
12:37:27.626: ---------------------------------
12:37:27.632: ---------------------------------
12:37:27.632: audio settings reset:
12:37:27.632: samples per sec: 44100
12:37:27.632: speakers: 2
12:37:27.662: ---------------------------------
12:37:27.662: Initializing D3D11...
12:37:27.662: Available Video Adapters:
12:37:27.663: Adapter 1: Radeon RX 550 Series
12:37:27.664: Dedicated VRAM: 4238626816
12:37:27.664: Shared VRAM: 4286212096
12:37:27.664: output 1: pos={0, 0}, size={1600, 900}, attached=true
12:37:27.666: Loading up D3D11 on adapter Radeon RX 550 Series (0)
12:37:28.432: D3D11 loaded successfully, feature level used: 45056
12:37:30.114: ---------------------------------
12:37:30.114: video settings reset:
12:37:30.114: base resolution: 1920x1080
12:37:30.114: output resolution: 1280x720
12:37:30.114: downscale filter: Bicubic
12:37:30.114: fps: 48/1
12:37:30.114: format: NV12
12:37:30.114: YUV mode: 601/Partial
12:37:30.146: Audio monitoring device:
12:37:30.146: name: Default
12:37:30.146: id: default
12:37:30.199: ---------------------------------
12:37:30.255: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
12:37:30.314: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:37:32.577: [AMF] A critical error occured during AMF Testing.
12:37:32.577: Failed to initialize module 'enc-amf.dll'
12:37:33.987: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
12:37:34.036: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
12:37:34.036: (127)
12:37:34.036: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
12:37:34.176: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
12:37:34.245: [obs-browser]: Version 2.1.5
12:37:34.749: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
12:37:34.749: (126)
12:37:35.708: Couldn't find VLC installation, VLC video source disabled
12:37:35.765: No blackmagic support
12:37:36.130: ---------------------------------
12:37:36.130: Loaded Modules:
12:37:36.130: win-wasapi.dll
12:37:36.130: win-mf.dll
12:37:36.130: win-dshow.dll
12:37:36.130: win-decklink.dll
12:37:36.130: win-capture.dll
12:37:36.130: vlc-video.dll
12:37:36.130: text-freetype2.dll
12:37:36.130: rtmp-services.dll
12:37:36.130: obs-x264.dll
12:37:36.130: obs-vst.dll
12:37:36.130: obs-transitions.dll
12:37:36.130: obs-text.dll
12:37:36.130: obs-qsv11.dll
12:37:36.130: obs-outputs.dll
12:37:36.130: obs-filters.dll
12:37:36.130: obs-ffmpeg.dll
12:37:36.130: obs-browser.dll
12:37:36.130: image-source.dll
12:37:36.130: frontend-tools.dll
12:37:36.130: enc-amf.dll
12:37:36.130: coreaudio-encoder.dll
12:37:36.148: ==== Startup complete ===============================================
12:37:36.186: Encoder ID 'amd_amf_h264' not found
12:37:36.881: All scene data cleared
12:37:36.881: ------------------------------------------------
12:37:37.132: WASAPI: Device 'Speakers (Logitech G430 Gaming Headset)' initialized
12:37:37.153: WASAPI: Device 'Microphone (High Definition Audio Device)' initialized
12:37:37.423: adding 278 milliseconds of audio buffering, total audio buffering is now 278 milliseconds
12:37:41.344: [window-capture: 'LolClient'] update settings:
12:37:41.344: executable: LeagueClientUx.exe
12:37:41.660: warning: deprecated pixel format used, make sure you did set range correctly
12:37:41.903: Switched to scene 'Scene'
12:37:41.949: ------------------------------------------------
12:37:41.949: Loaded scenes:
12:37:41.949: - scene 'Scene':
12:37:41.949: - source: 'wallpaper' (image_source)
12:37:41.949: - source: 'LolClient' (window_capture)
12:37:41.949: - source: 'League of Legends' (game_capture)
12:37:41.949: - source: 'Macros' (image_source)
12:37:41.949: - source: 'Webcam' (dshow_input)
12:37:41.949: - scene 'Scene 2':
12:37:41.949: - source: 'Image' (image_source)
12:37:41.949: - source: 'webcam' (dshow_input)
12:37:41.949: - source: 'Fortnite' (game_capture)
12:37:43.923: CalculateFileHash: Failed to open file 'C:\Users\Heriberto\AppData\Roaming\obs-studio\updates\whatsnew.json':
12:37:53.808: ---------------------------------
12:37:53.809: [DShow Device: 'Webcam'] settings updated:
12:37:53.809: video device: C922 Pro Stream Webcam
12:37:53.809: video path: \\?\usb#vid_046d&pid_085c&mi_00#7&80b83a6&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
12:37:53.809: resolution: 640x480
12:37:53.809: fps: 30.00 (interval: 333333)
12:37:53.809: format: YUY2
12:37:53.883: ---------------------------------
12:37:53.883: [DShow Device: 'webcam'] settings updated:
12:37:53.883: video device: C922 Pro Stream Webcam
12:37:53.883: video path: \\?\usb#vid_046d&pid_085c&mi_00#7&80b83a6&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
12:37:53.883: resolution: 1920x1080
12:37:53.883: fps: 30.00 (interval: 333333)
12:37:53.883: format: MJPEG
12:37:53.959: DShow: HDevice::ConnectPins: failed to connect pins (0x80040207): The owner SID on a per-user subscription doesn't exist
12:37:53.959:
12:37:55.666: DShow: Run failed (0x800705AA): Insufficient system resources exist to complete the requested service.
12:37:55.666:
12:43:08.369: Stream output type 'rtmp_output' failed to start!
12:43:20.178: Stream output type 'rtmp_output' failed to start!
12:43:30.908: [game-capture: 'League of Legends'] attempting to hook process: League of Legends.exe
12:43:30.939: [game-capture: 'League of Legends'] using helper (compatibility hook)
12:43:31.231: [game-capture: 'League of Legends'] hook not loaded yet, retrying..
12:43:33.929: [game-capture: 'League of Legends'] attempting to hook process: League of Legends.exe
12:43:35.658: [game-capture: 'League of Legends'] capture stopped
12:43:37.951: [game-capture: 'League of Legends'] attempting to hook process: League of Legends.exe
12:43:37.971: [game-capture: 'League of Legends'] capture stopped
12:43:41.970: [game-capture: 'League of Legends'] attempting to hook process: League of Legends.exe
12:43:41.991: [game-capture: 'League of Legends'] capture stopped
12:43:45.991: [game-capture: 'League of Legends'] attempting to hook process: League of Legends.exe
12:43:46.025: [game-capture: 'League of Legends'] capture stopped
12:43:50.038: [game-capture: 'League of Legends'] attempting to hook process: League of Legends.exe
12:43:50.094: [game-capture: 'League of Legends'] shared texture capture successful
12:45:55.192: Stream output type 'rtmp_output' failed to start!
12:47:54.611: [game-capture: 'League of Legends'] d3d9 shared texture capture successful
12:47:54.616: [game-capture: 'League of Legends'] shared texture capture successful
13:14:05.786: [game-capture: 'League of Legends'] capture window no longer exists, terminating capture
13:14:05.786: [game-capture: 'League of Legends'] capture stopped
13:18:40.702: Stream output type 'rtmp_output' failed to start!
13:26:40.656: Stream output type 'rtmp_output' failed to start!
13:39:33.641: Stream output type 'rtmp_output' failed to start!
13:41:40.576: Stream output type 'rtmp_output' failed to start!
Sorry if this is too much info
