Problem is Audio and FPS when streaming/recording
NAAA
Hello I’m looking for some help with OBS, when streaming/recording I used 1920x1080 60fps but when I check my recording it’s super laggy. But when I change it to 30fps it’s smooth but the audio of my gameplay is off by like a second. I play valorant if that helps. As for my component I have a Ryzen 7 7800X3D, Nvidea 4060ti. Also for the OBS setting I have it copied from a YouTube video https://youtu.be/0eITm_XGELg and https://youtu.be/dDXungSblDI
If you need more information I’d be happy to give.
Rule #1 Don't copy OBS settings from YouTube unless they're from @EposVox
Rule #2 Tools > Auto Config Wizard > DO NOT CHANGE ANYTHING and close and restart OBS.
If still having issues
