I'm not able to install OBS in 32bit windows. Everytime I try, it shows me something is missing, entry point error etc. I have tried my best to resolve all the issues but still it's the same. What should I do now?
If you ask me, you should reinstall and put 64-bit Windows 10 on your machine. Your hardware is capable of 64-bit (if it is not, it is too weak to support OBS in the first place), and during the new install you will eliminate the messed up operating system issue that prevents you from properly install software.
Your Windows key is valid for 32-bit as well as 64-bit, so you don't need to purchase Windows again. Just install again from original Windows media:
