Hi Folks:
I'm trying to help a friend, who's native language isn't English, set up OBS on his laptop.
The game is World of Tanks, and the image Twitch broadcasts is a large portion of the center of the external 1920 x 1080 monitor he plays on.
The highest resolution he is able to select for "Resolution Downscale" is "None (1536 x 864)", which is the resolution of the Laptop's monitor.
It looks to me like he's broadcasting the center 1536 x 864 pixels of a 1920 x 1080 display.
We spent some time trying get his OBS settings as much like mine as he can. I have Nvidea, his system, as you can see in the log, uses the i5's internal controller.
Any ideas what we're doing wrong?
Thanks
Larry.
Thanks
Larry.
4:18:48: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
14:18:48: 14:18:48: CPU Name: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
14:18:48: CPU Speed: 1600MHz
14:18:48: Physical Memory: 3991MB Total, 1143MB Free
14:18:48: stepping id: 1, model 69, family 6, type 0, extmodel 2, extfamily 0, HTT 1, logical cores 4, total cores 2
14:18:48: monitor 1: pos={0, 0}, size={1536, 864}
14:18:48: Windows Version: 6.2 Build 9200
14:18:48: Aero is Enabled
14:18:48: 14:18:48: OBS Modules:
14:18:48: Base Address Module
14:18:48: 00140000 OBS.exe
14:18:48: 61350000 OBSApi.dll
14:18:48: 62050000 DShowPlugin.dll
14:18:48: 61840000 GraphicsCapture.dll
14:18:48: 61810000 NoiseGate.dll
14:18:48: 617F0000 PSVPlugin.dll
14:18:48: 617D0000 scenesw.dll
14:18:48: 14:18:48: Adapter 1
14:18:48: Video Adapter: Intel(R) HD Graphics Family
14:18:48: Video Adapter Dedicated Video Memory: 0
14:18:48: Video Adapter Shared System Memory: 1879048192
14:18:48: Video Adapter Output 1: pos={0, 0}, size={1536, 864}, attached=true
14:18:48: =====Stream Start: 2015-06-27, 14:18:48===============================================
14:18:48: Multithreaded optimizations: On
14:18:48: Base resolution: 1536x864
14:18:48: Output resolution: 1536x864
14:18:48: 14:18:48: Loading up D3D10 on Intel(R) HD Graphics Family (Adapter 1)...
14:18:48: 14:18:48: Audio Format: 48000 Hz
14:18:48: 14:18:48: Audio Channels: 2 Ch
14:18:48: Playback device Default
14:18:48: 14:18:48: Using desktop audio input: Lautsprecher (3- Logitech G930 Headset)
14:18:48: Global Audio time adjust: 0
14:18:48: Using 7.1 surround speaker setup
14:18:48: 14:18:48: Using auxilary audio input: Mikrofon (3- Logitech G930 Headset)
14:18:48: Mic time offset: 0
14:18:48: 14:18:48: Audio Encoding: AAC
14:18:48: bitrate: 96
14:18:48: Using graphics capture
14:18:48: Trying to hook process: WorldOfTanks.exe
14:18:48: Scene buffering time set to 700
14:18:48: 14:18:48: Video Encoding: x264
14:18:48: fps: 30
14:18:48: width: 1536, height: 864
14:18:48: preset: veryfast
14:18:48: profile: high
14:18:48: keyint: 250
14:18:48: CBR: yes
14:18:48: CFR: yes
14:18:48: max bitrate: 1000
14:18:48: buffer size: 1000
14:18:48: 14:18:50: Using RTMP service: Twitch
14:18:50: Server selection: rtmp://live-iad.twitch.tv/app
14:18:50: Interface: Controller der Familie Realtek PCIe GBE (ethernet, 1000 mbps)
14:18:50: Completed handshake with rtmp://live-iad.twitch.tv/app in 394 ms.
14:18:50: SO_SNDBUF was at 65536
14:18:52: SharedTexCapture hooked
