Question / Help Obs studio quality not clear 720p60fps
akshaydbc
I recorded with obs studio and uploaded to youtube and I watched in 720p60 fps in my mobile and it is not as clear as it should be. What is the issue?
When you watch the recorded video back on your PC, does it still have quality issues? Do they resolve themselves if you watch the original video using the VLC video player? If you watch the uploaded video on Youtube on your PC, does it have the visual quality problem still?
Lots of reasons could cause this, anything from YouTube's re-encoding of the video you uploaded, to your mobile device re-scaling the video to fit the smaller screen.
Yes, I watched in VLC player, it still looks blurry. I watched in youtube also in my pc. It is blurry. I will attach the log file also!
No recording session in the log.
Open OBS, start an output session, observe your issue, stop the output session, then upload the Current log without quitting OBS.
first 1364x768 <-- is not 720P
and why you use CBR thats a useless limiter for the quality of record
on record you use default a Quality target not a bitrate target
its not a issue
set the base resolution to 720P(NO Rescale <-- will result in "blurry" too)
switch from bitrate to quality ~15
then its nearly 1:1 if its not like you wish reduce the 15 to 14/13/12
its not a issue
Tried with both base and output resolution as 720p! Still blurry! Are you saying CQP??
you can only verify the record quality on your pc with media player like vlc/mpc/...
if you upload it to youtube it will be reencoded so you never know its wrong record or wrond reencode
after change base resolution its recommended to restart obs
and 14 is not really a problem its sometimes in the first seconds a short "overflow"
have that same in 1-2 of 30 starts
if its not increase after the first 10-20s its fine
quality now better?
