YeahThePro
I only have 1 mbps upload speed BUT I'm upgrading my net to 2mbps upload this week.
My PC specs:
CPU: i7 4790K (4ghz / runs at 4.2-4.4)
GPU: GTX 960 (2GB)
RAM: 8 GB
So here are my questions. What should I use and what are the pros and cons of every choice;
1) Encoder: x264 or nvidia NVENC
2) max rate kbps ? / buffer size ?
3) audio codec ? bitrate ? stereo or mono ?
4) fps ? (i use 25 now)
5) ANY help regarding "ADVANCED OPTIONS" is appreciated I'm a total noob when it comes to those. My main questions are whether I should use CFR and CBR and what x264 cpu preset I should use with the CPU I own. Right now I use "veryfast". Should I go for "fast" or lower, or that will damage/overheat my CPU ?
Any kind of help is appreciated! :) Thanks for your time.
My PC specs:
GPU: GTX 960 (2GB)
RAM: 8 GB
