Today my OBS recordings started having audio problems. No matter how low or high the audio (of the game) is I can hear like a metallic echo sound and gets choppy. I'm using an Elgato HD60 Pro to record my Nintendo Switch. Been searching online for a fix but I have no luck.
Example of the audio: https://www.youtube.com/watch?v=XFmCfCTHu3s (at the beginning and around 0:09 to 00:12.)
Log url: https://obsproject.com/logs/0vDWMNyZKhLrD12v
22:53:47.223: CoInitializeEx succeeded: 0x00000001
22:53:47.223: CPU Name: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
22:53:47.223: CPU Speed: 3696MHz
22:53:47.223: Physical Cores: 6, Logical Cores: 12
22:53:47.223: Physical Memory: 32696MB Total, 26883MB Free
22:53:47.223: Windows Version: 10.0 Build 18363 (release: 1909; revision: 815; 64-bit)
22:53:47.223: Running as administrator: false
22:53:47.223: Aero is Enabled (Aero is always on for windows 8 and above)
22:53:47.224: Windows 10 Gaming Features:
22:53:47.224: Game Bar: On
22:53:47.224: Game DVR: On
22:53:47.224: Game DVR Background Recording: Off
22:53:47.224: Game Mode: Off
22:53:47.225: Sec. Software Status:
22:53:47.226: Windows Defender Antivirus: enabled (AV)
22:53:47.226: Windows Firewall: enabled (FW)
22:53:47.226: Current Date/Time: 2020-05-09, 22:53:47
22:53:47.226: Browser Hardware Acceleration: true
22:53:47.226: Portable mode: false
22:53:47.532: OBS 25.0.8 (64-bit, windows)
22:53:47.532: ---------------------------------
22:53:47.550: ---------------------------------
22:53:47.550: audio settings reset:
22:53:47.550: samples per sec: 48000
22:53:47.550: speakers: 2
22:53:47.550: Initializing D3D11...
22:53:47.550: Available Video Adapters:
22:53:47.554: Adapter 0: NVIDIA GeForce RTX 2070 SUPER
22:53:47.554: Dedicated VRAM: 4105175040
22:53:47.554: Shared VRAM: 4257447936
22:53:47.554: PCI ID: 10de:1e84
22:53:47.554: Driver Version: 26.21.14.4587
22:53:47.554: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=144, name=VG248
22:53:47.556: Loading up D3D11 on adapter NVIDIA GeForce RTX 2070 SUPER (0)
22:53:47.602: D3D11 loaded successfully, feature level used: b000
22:53:47.602: DXGI increase maximum frame latency success
22:53:47.602: D3D11 GPU priority setup failed (not admin?)
22:53:47.960: ---------------------------------
22:53:47.960: video settings reset:
22:53:47.960: base resolution: 1920x1080
22:53:47.960: output resolution: 1920x1080
22:53:47.960: downscale filter: Lanczos
22:53:47.960: fps: 60/1
22:53:47.960: format: NV12
22:53:47.960: YUV mode: 601/Partial
22:53:47.960: NV12 texture support enabled
22:53:47.961: Audio monitoring device:
22:53:47.961: name: Default
22:53:47.961: id: default
22:53:47.961: ---------------------------------
22:53:47.963: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
22:53:47.964: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
22:53:47.993: [AMF] Unable to load 'amfrt64.dll', error code 126.
22:53:47.995: [AMF] AMF Test failed due to one or more errors.
22:53:47.995: Failed to initialize module 'enc-amf.dll'
22:53:48.011: [obs-browser]: Version 2.8.6
22:53:48.014: NVENC supported
22:53:48.077: VLC found, VLC video source enabled
22:53:48.080: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
22:53:48.081: No blackmagic support
22:53:48.084: ---------------------------------
22:53:48.084: Loaded Modules:
22:53:48.084: win-wasapi.dll
22:53:48.084: win-mf.dll
22:53:48.084: win-ivcam.dll
22:53:48.084: win-dshow.dll
22:53:48.084: win-decklink.dll
22:53:48.084: win-capture.dll
22:53:48.084: vlc-video.dll
22:53:48.084: text-freetype2.dll
22:53:48.084: rtmp-services.dll
22:53:48.084: obs-x264.dll
22:53:48.084: obs-vst.dll
22:53:48.084: obs-transitions.dll
22:53:48.084: obs-text.dll
22:53:48.084: obs-qsv11.dll
22:53:48.084: obs-outputs.dll
22:53:48.084: obs-filters.dll
22:53:48.084: obs-ffmpeg.dll
22:53:48.084: obs-browser.dll
22:53:48.084: image-source.dll
22:53:48.084: frontend-tools.dll
22:53:48.084: enc-amf.dll
22:53:48.084: decklink-ouput-ui.dll
22:53:48.084: coreaudio-encoder.dll
22:53:48.084: ==== Startup complete ===============================================
22:53:48.087: All scene data cleared
22:53:48.087: ------------------------------------------------
22:53:48.116: WASAPI: Device 'Headphones (UA | JBL Train Stereo)' [44100 Hz] initialized
22:53:48.116: [Loaded global audio device]: 'Desktop Audio'
22:53:48.128: WASAPI: Device 'Headphones (UA | JBL Train Stereo)' [44100 Hz] initialized
22:53:48.128: [Loaded global audio device]: 'VLC Music'
22:53:48.145: WASAPI: Device 'Microphone (NVIDIA RTX Voice)' [48000 Hz] initialized
22:53:48.145: [Loaded global audio device]: 'Mic/Aux'
22:53:48.146: [window-capture: 'Window Capture'] update settings:
22:53:48.146: executable: NintendoSpy.exe
22:53:48.178: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
22:53:48.178:
22:53:48.740: Switched to scene 'Elgato Capture'
22:53:48.740: ------------------------------------------------
22:53:48.740: Loaded scenes:
22:53:48.740: - scene 'Elgato Capture':
22:53:48.740: - source: 'Elgato HD60 Pro' (dshow_input)
22:53:48.740: - scene 'Smash Melee':
22:53:48.740: - source: 'Dolphin' (game_capture)
22:53:48.740: - source: 'Layout' (image_source)
22:53:48.740: - source: 'Webcam' (dshow_input)
22:53:48.740: - source: 'Window Capture' (window_capture)
22:53:48.740: - filter: 'Chroma Key' (chroma_key_filter)
22:53:48.740: - scene 'PC Gaming':
22:53:48.740: - source: 'Game Capture' (game_capture)
22:53:49.204: ---------------------------------
22:53:49.204: [DShow Device: 'Webcam'] settings updated:
22:53:49.204: video device: Logitech HD Webcam C270
22:53:49.204: video path: \\?\usb#vid_046d&pid_0825&mi_00#6&36e5dab4&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
22:53:49.204: resolution: 640x480
22:53:49.204: flip: 0
22:53:49.204: fps: 30.00 (interval: 333333)
22:53:49.204: format: I420
22:53:49.373: ---------------------------------
22:53:49.373: [DShow Device: 'Elgato HD60 Pro'] settings updated:
22:53:49.373: video device: Elgato Game Capture HD
22:53:49.373: video path: __elgato
22:53:49.373: resolution: 1920x1080
22:53:49.373: flip: 0
22:53:49.373: fps: 60.00 (interval: 166666)
22:53:49.373: format: UYVY
22:53:49.373: using video device audio: yes
22:53:49.373: sample rate: 48000
22:53:49.373: channels: 2
22:53:49.373: audio type: Capture
22:56:50.542: Settings changed (outputs)
22:56:50.542: ------------------------------------------------
