Hello everybody. Here is my problem: I´m triying to set up my Avermedia capture device for streaming with OBS. I tried everything I found on the Internet but I still can´t make it work. Allways I add a Video Capture Devide into my scene, go to device selection, select LGP Stream Engine and try to apply the changes it gives me a "Invalid resolution" error. The resolution box is blank. If I try to set the resolution manually checking the "Custom Resolution" box there is no option to select. If I set it manually, for example tiping 1920x1080 or 1280x720 it gives me a "The device does not support that resolution" error. When I click on the configuration button it doesn´t do anything.
Here is a list of everything I´m using right now and what I´ve tried until now:
- Avermedia streaming software: LGP Stream Engine (ver. 1.3.0.16)
Installed the three versions.
- Avermedia software: RECentral (ver. 1.3.3.117.2018101201)
Uninstaled and reinstalled several times.
- Avermedia Firmware:
Just installed it.
- Capture Device: Avermedia LGP Lite GL310 USB HD Capture Device
- Broadcast Software: OBS Classic (0.659b and 32bits)
I´ve tried with OBS 22.0, 21.0 18.0, 16.0 and 14.0 (both 32 bits and 64)
- Console: PS4
It´s a PS4... nothing more to say.
- Complements: Splitter (for ps3, you know...)
I´ve tried disconecting it.
- PC software: Chrome
I uninstaled Skype and end all Google Chrome processes.
Thank you in advance.
Just installed it.
- Console: PS4
