Lower output fps problem. Need some help!
So to be short - my output video is "ok" if you look into its properties, but you can see a tiny glitches and it's definitely not capturing all 60fps. I would say it's like 50 or something.
I'm attaching a link for the OBS log file here.
I would appreciate any help with OBS settings to run a SMOOTH picture in my recordings output just as I see it at my "source" monitor (TV). Spent days on that already...
Thanks.
Interesting that putting elgato in Sources tab to its Preset settings and keeping the same resolution in Video settings completely solves my problem! BUT, there is no 1440p in Presets and if I put it manually -- I'm back to my previous results...
Please, help )
