Question / Help Livestream Is laggy and not really HD HELP!
Hey can u Help me to make my Livestream better ?
My Processor : AMD FX-8350 4.0 ghz
Upload: 5,63mbps
and with my settings is all shitty and laggy ...
any can help me with my settings please ???
Thanks
Oh found it here it is :
20:40:09: CLR host plugin strings not found, dynamically loading 4 strings
20:40:09: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
20:40:09: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
20:40:09: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
20:40:09: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
20:40:09: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
20:40:09: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
20:40:10: CLRHost:: Could not find/load browser settings at location C:\Users\Kevin\AppData\Roaming\OBS\pluginData\browser.json
20:40:10: CLRHost:: Exception: System.IO.FileNotFoundException: Die Datei "C:\Users\Kevin\AppData\Roaming\OBS\pluginData\browser.json" konnte nicht gefunden werden.
20:40:10: Dateiname: 'C:\Users\Kevin\AppData\Roaming\OBS\pluginData\browser.json'
20:40:10: bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
20:40:10: bei System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
20:40:10: bei System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
20:40:10: bei CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
20:40:10: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
20:54:24: Open Broadcaster Software v0.65b - 32bit (´・ω・`)
20:54:24: -------------------------------
20:54:24: CPU Name: AMD FX(tm)-8350 Eight-Core Processor
20:54:24: CPU Speed: 3991MHz
20:54:24: Physical Memory: 4095MB Total, 2949MB Free
20:54:24: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 8
20:54:24: monitor 1: pos={0, 0}, size={1360, 768}
20:54:24: Windows Version: 6.1 Build 7601 S
20:54:24: Aero is Disabled
20:54:24: OBS Modules:
20:54:24: Base Address Module
20:54:24: 01030000 OBS.exe
20:54:24: 6A3A0000 OBSApi.dll
20:54:24: 6BE30000 CLRHostPlugin.dll
20:54:24: 6B090000 DShowPlugin.dll
20:54:24: 6ADE0000 GraphicsCapture.dll
20:54:24: 6ADB0000 NoiseGate.dll
20:54:24: 6BBF0000 PSVPlugin.dll
20:54:24: 6BB90000 scenesw.dll
20:54:24: ------------------------------------------
20:54:24: Adapter 1
20:54:24: Video Adapter: AMD Radeon R9 200 Series
20:54:24: Video Adapter Dedicated Video Memory: 3199393792
20:54:24: Video Adapter Shared System Memory: 4003856384
20:54:24: Video Adapter Output 1: pos={0, 0}, size={1360, 768}, attached=true
20:54:24: =====Stream Start: 2015-03-24, 20:54:24===============================================
20:54:24: Multithreaded optimizations: On
20:54:24: Base resolution: 1280x720
20:54:24: Output resolution: 1280x720
20:54:24: Loading up D3D10 on AMD Radeon R9 200 Series (Adapter 1)...
20:54:24: Audio Format: 48000 Hz
20:54:24: Audio Channels: 2 Ch
20:54:24: Playback device Default
20:54:24: Using desktop audio input: 1 - DTV (AMD High Definition Audio Device)
20:54:24: Global Audio time adjust: 0
20:54:24: Audio Encoding: AAC
20:54:24: bitrate: 128
20:54:25: ------------------------------------------
20:54:25: device: Elgato Game Capture HD,
20:54:25: device id {39F50F4C-99E1-464A-B6F9-D605B4FB5918},
20:54:25: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 166833-166833
20:54:25: use buffering: true - 0, fourCC: 'UYVY'
20:54:25:
20:54:25: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
20:54:25: Elgato Game Capture: force buffering with 1 msec
20:54:25: Using directshow input
20:54:25: Scene buffering time set to 700
20:54:25: Video Encoding: x264
20:54:25: fps: 60
20:54:25: width: 1280, height: 720
20:54:25: preset: veryfast
20:54:25: profile: high
20:54:25: keyint: 250
20:54:25: CBR: yes
20:54:25: CFR: yes
20:54:25: max bitrate: 3000
20:54:25: buffer size: 3000
20:54:27: CLRHost:: Browser 1: Status message:
20:54:44: FlushBufferedVideo: Flushing 21 packets over 333 ms
20:54:45: Total frames encoded: 1122, total frames duplicated: 0 (0.00%)
20:54:45: Total frames rendered: 1150, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
20:55:00:
20:55:00: Profiler time results:
20:55:00:
20:55:00: ==============================================================
20:55:00: video thread frame - [100%] [avg time: 1.544 ms] [children: 68.7%] [unaccounted: 31.3%]
20:55:00: | scene->Preprocess - [54.2%] [avg time: 0.837 ms]
20:55:00: | GPU download and conversion - [14.4%] [avg time: 0.223 ms] [children: 13.2%] [unaccounted: 1.23%]
20:55:00: | | flush - [11.4%] [avg time: 0.176 ms]
20:55:00: | | CopyResource - [0.777%] [avg time: 0.012 ms]
20:55:00: | | conversion to 4:2:0 - [1.04%] [avg time: 0.016 ms]
20:55:00: Convert444Threads - [100%] [avg time: 0.41 ms] [children: 97.8%] [unaccounted: 2.2%]
20:55:00: | Convert444toNV12 - [97.8%] [avg time: 0.401 ms]
20:55:00: encoder thread frame - [100%] [avg time: 1.438 ms] [children: 0.139%] [unaccounted: 99.9%]
20:55:00: | sending stuff out - [0.139%] [avg time: 0.002 ms]
20:55:00:
20:55:00:
20:55:00: Profiler CPU results:
20:55:00:
20:55:00: video thread frame - [cpu time: avg 0.895 ms, total 1029.61 ms] [avg calls per frame: 1]
20:55:00: | scene->Preprocess - [cpu time: avg 0.786 ms, total 904.804 ms] [avg calls per frame: 1]
20:55:00: | GPU download and conversion - [cpu time: avg 0.054 ms, total 62.402 ms] [avg calls per frame: 1]
20:55:00: | | flush - [cpu time: avg 0.054 ms, total 62.402 ms] [avg calls per frame: 1]
20:55:00: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:55:00: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:55:00: Convert444Threads - [cpu time: avg 0.389 ms, total 2574.02 ms] [avg calls per frame: 6]
20:55:00: | Convert444toNV12 - [cpu time: avg 0.379 ms, total 2511.62 ms] [avg calls per frame: 6]
20:55:00: encoder thread frame - [cpu time: avg 1.062 ms, total 1170.01 ms] [avg calls per frame: 1]
20:55:00: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:55:00:
20:55:00: =====Stream End: 2015-03-24, 20:55:00=================================================
21:01:34: CLR host plugin instance deleted; removing dynamically loaded localization strings
21:01:34: Terminating 0xc20
