Question / Help IShowU Audio Capture is Capturing Audio... But I can not hear the audio?
Oliivxa
It says It is capturing the audio, But because the audio is an output, I can't hear it. I just downloaded OBS so I am very new to this so I do not understand. I am trying to live stream me drawing, but I also want to hear the music I play.
Narcogen
What iShowU has done for you is to create a virtual audio device that OBS can see, because MacOS doesn't present its default output in a manner that OBS can capture.
Now you need a way to hear it.
OBS has a way built-in. In Settings > Audio you can select a hardware output device for monitoring.
And in Edit > Advanced Audio Properties, you can select which audio sources you want OBS to send to that monitor by selecting "monitor and output" from the drop down menu.
