Is there a way to switch from horizontal to portrait scenes from OBS?
Happyhyogan
Hello,
I’d like to switch between streaming from my MacBook and my mobile all in one stream. I’ve downloaded OBS studio on my mobile and can successfully connect my mobile to my OBS on my MacBook. I can successfully see myself and switch from one scene from my computer to the scene to show my mobile camera however, it shows vertical display in horizontal .. so it’s black on both sides and then there’s the mobile view … I appear small unfortunately. how can I switch my mobile scene into full portrait mode and NOT portrait in horizontal mode?
Hope that makes sense.
Thank you
I previously had a similar issue, when switching between 32x9 side by side proper ratio 3D to 16x9 2D. You can't do it without stopping the broadcast.
And in order to do that you have to change the profile. A profile can only have one ratio and so can a broadcast.
It's determined by the resolution of your broadcast.
