Bug Report Imported fonts unload when going back into OBS after a shutdown
frisbii
I have Roboto Mono installed from here on my OS, and OBS picks that up fine when it's first installed; the Text (GDI+) source works as expected. However, if I shut down my computer, when I turn it on again and open OBS, the fonts have unloaded.
The font preview works, however the properties preview is blank and the actual source appears blank as well. The only fix I have for this is to close OBS, reinstall the font, then open OBS again. After that, they appear normally again. How can I fix this?
logs
I am having a similar issue with Astloch Bold that is only displaying problems with the Text GDI+ text type, where I can type in the font fine enough, but it does not display the text from a .txt file when using -Read from file- option.
