my audio works but the problem is i cant hear what characters say or my characters movement at times.
I started playing Luigi's mansions 3 and the first cutscene all i can hear was the audio the characters grunt were non existent but when i get to the playable part of the game everything goes back to normal.
After Luigi's mansion i was playing dragon ball breakers beta Vers and trunks and the raiders voices weren't working but npc's noises were i have a video out on my Youtube channel if it helps you to understand what i mean
ive also been testing some of my games to see if i can hear any voices and such and it seems that some work while others dont pick up the voice or the voices are just vary quiet
if you are wondering what HDMI im using is DIGITNOW Video Capture Card 4K HDMI Video Capture Device with Loop Out, Full HD 1080P Game Capture Video Recorder for Live Streaming, Broadcasting or Video Conference i found on Amazon i will leave a link if it helps
but i've been trying to adjust my audio with no luck on the setting and on the video capture device if you have any suggestions of what i try to do i would greatly appreciated and thanks in advance
log file - https://obsproject.com/logs/rzBXzoTJ-qAN4OJH
video - https://youtu.be/HdssuvXsdkE?list=PLE3Qpf7W2I-ja2otzn0XQ7d7mt396XdK2
HDMI - https://www.amazon.com/dp/B08DQYNDWN?psc=1&ref=ppx_yo2ov_dt_b_product_details
