Help. Stream someone else's computer screen and audio?
JoshuaCasper
Hello. My name is Joshua.
I am looking to run a stream from my office with OBS and allow a remote guest to not only join the stream with a mic and webcam, but also share their computer screens and sounds. They would be using digital audio workstations (DAWs) and plugins in them.
The closest I have gotten is a boosted Discord server.
However, you have to share just a specific app in Discord to hear the app audio. When sharing a DAW app window, it auto zooms in to the nested plugin UIs and even into menus. It does it erratically too. Unwatchable, really. Furthermore, if we switch it to share full screen, the sound isn't shared.
What are some other alternatives to discord that work with OBS? I think OBS-Ninja works, but I am wondering if there is anything else.
I am on Windows 11, the most current version of OBS, and a really beefy computer.
Thanks in advance.
cyclemat
on DAWS use Display capture cant say much more over your audio problem didnt know witch daw and did you use asio ? Discord cant work right with asio drivers !
