I've been browsing the internet for hours trying to resolve this problem! Using display capture is out of my comfort zone and I really would like to get this fixed
I do not have duo graphics cards and I'm using a desktop PC
Running OBS as admin and in compatibility mode has not done anything
OpenGL is turned off on my Photoshop, but it still doesn't show up in OBS
Window capture sometimes picks up Chrome but other than that it's extremely unreliable, oddly enough, Drawpile (digital painting software) shows up from time to time in the menu
Game capture does not pick up anything at all
Here are some logs, thanks in advance for the assistance
10:36:14.638: CPU Name: AMD A8-3870 APU with Radeon(tm) HD Graphics
10:36:14.638: CPU Speed: 3000MHz
10:36:14.638: Physical Cores: 4, Logical Cores: 4
10:36:14.638: Physical Memory: 8189MB Total, 5180MB Free
10:36:14.638: Windows Version: 10.0 Build 10240 (revision: 17709; 64-bit)
10:36:14.638: Running as administrator: true
10:36:14.638: Aero is Enabled (Aero is always on for windows 8 and above)
10:36:14.638: Windows 10 Gaming Features:
10:36:14.638: Game Bar: Off
10:36:14.638: Game DVR Allowed: Yes
10:36:14.639: Game DVR: Off
10:36:14.639: Game DVR Background Recording: Off
10:36:14.639: Game Mode: Off
10:36:14.640: Portable mode: false
10:36:14.720: OBS 20.1.3 (64bit, windows)
10:36:14.720: ---------------------------------
10:36:14.748: ---------------------------------
10:36:14.748: audio settings reset:
10:36:14.748: samples per sec: 44100
10:36:14.748: speakers: 2
10:36:14.793: ---------------------------------
10:36:14.793: Initializing D3D11...
10:36:14.793: Available Video Adapters:
10:36:14.795: Adapter 1: NVIDIA GeForce GT 740
10:36:14.795: Dedicated VRAM: 1044054016
10:36:14.795: Shared VRAM: 4293513216
10:36:14.796: output 1: pos={0, 0}, size={1920, 1080}, attached=true
10:36:14.799: Loading up D3D11 on adapter NVIDIA GeForce GT 740 (0)
10:36:14.829: D3D11 loaded successfully, feature level used: 45056
10:36:16.437: ---------------------------------
10:36:16.438: video settings reset:
10:36:16.438: base resolution: 1920x1080
10:36:16.438: output resolution: 1920x1080
10:36:16.438: downscale filter: Bicubic
10:36:16.438: fps: 30/1
10:36:16.438: format: NV12
10:36:16.440: Audio monitoring device:
10:36:16.440: name: Default
10:36:16.440: id: default
10:36:16.440: ---------------------------------
10:36:16.614: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
10:36:16.655: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
10:36:16.727: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
10:36:16.727: Failed to initialize module 'enc-amf.dll'
10:36:17.524: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
10:36:17.561: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
10:36:17.599: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
10:36:17.666: Failed to load 'en-US' text for module: 'obs-browser.dll'
10:36:17.666: [browser_source: 'Version: 1.29.0']
10:36:18.171: NVENC supported
10:36:18.819: Couldn't find VLC installation, VLC video source disabled
10:36:18.961: No blackmagic support
10:36:19.278: ---------------------------------
10:36:19.278: Loaded Modules:
10:36:19.278: win-wasapi.dll
10:36:19.278: win-mf.dll
10:36:19.278: win-dshow.dll
10:36:19.278: win-decklink.dll
10:36:19.278: win-capture.dll
10:36:19.278: vlc-video.dll
10:36:19.278: text-freetype2.dll
10:36:19.278: rtmp-services.dll
10:36:19.278: obs-x264.dll
10:36:19.278: obs-vst.dll
10:36:19.278: obs-transitions.dll
10:36:19.278: obs-text.dll
10:36:19.278: obs-qsv11.dll
10:36:19.278: obs-outputs.dll
10:36:19.278: obs-filters.dll
10:36:19.278: obs-ffmpeg.dll
10:36:19.278: obs-browser.dll
10:36:19.278: image-source.dll
10:36:19.278: frontend-tools.dll
10:36:19.278: enc-amf.dll
10:36:19.278: coreaudio-encoder.dll
10:36:19.278: ==== Startup complete ===============================================
10:36:19.280: Service '' not found
10:36:19.329: All scene data cleared
10:36:19.329: ------------------------------------------------
10:36:19.426: WASAPI: Device 'Speakers (High Definition Audio Device)' initialized
10:36:19.447: WASAPI: Device 'Microphone (High Definition Audio Device)' initialized
10:36:19.486: Switched to scene 'Photoshop'
10:36:19.489: ------------------------------------------------
10:36:19.489: Loaded scenes:
10:36:19.489: - scene 'Scene':
10:36:19.489: - source: 'Video Capture Device' (dshow_input)
10:36:19.489: - scene 'Photoshop':
10:36:19.489: - source: 'Window Capture' (window_capture)
10:36:19.489: - scene 'SAI':
10:36:19.489: - source: 'Window Capture 2' (window_capture)
10:36:19.489: - source: 'Window Capture 3' (window_capture)
10:36:19.489: - scene 'Draw':
10:36:19.489: - source: 'Window Capture 4' (window_capture)
10:36:19.493: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
10:36:20.241: ---------------------------------
10:36:20.241: [DShow Device: 'Video Capture Device'] settings updated:
10:36:20.241: video device: USB2.0 Camera
10:36:20.241: video path: \\?\usb#vid_1e4e&pid_0102&mi_00#7&64efd08&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
10:36:20.241: resolution: 640x480
10:36:20.241: fps: 30.00 (interval: 333333)
10:36:20.241: format: YUY2
10:36:28.723: User switched to scene 'SAI'
10:36:29.279: User switched to scene 'Draw'
10:36:30.094: User switched to scene 'Photoshop'
10:36:30.948: User switched to scene 'SAI'
10:36:31.272: User switched to scene 'Photoshop'
10:37:10.127: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
10:42:10.361: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
10:43:11.138: User switched to scene 'SAI'
10:48:22.091: adding 23 milliseconds of audio buffering, total audio buffering is now 116 milliseconds
