Hello all I am in need of some help. I have been using OBS Studio for years now and I have never had this issue until a month ago. From the title of the Thread you can see I am dropping frames, but this is where it gets weird. In the picture below you can see my ratio frames, for example When I am live I will have 35/60 frames but my dropped frames percentage will be 0 (0%) I just loose frames and OBS doesn't register that i am dropping frames resulting in some really bad content. I have lost viewer ship over this and I am all around lost at this point.
This issue happens when both recording and live. The picture below is only from recording where it doesnt display the dropped frames percentage.
Games I play when this happens are; Escape From Tarkov (Main game), Counter Strike 2, GTA, and many other Triple A title games.
My build:
Single pc
64 Gb 3200 MhZ Ram Gskill
NVIDIA 3060 Asus ROG Stix Gpu
I have my obs on a NvME SSD
AMD Ryzen 5950x (AM4 Platform) CPU
Steps that I have taken to resolve this issue,
-Played with my bit rate
-Switched From Nvenc H.264 to x264 for both recording and streamign (This has helped alot prior to do this MY frames would be 15/60 with a 0% Frame drop)
-Scanned for virsues
-Used optimal setting for all setups
-Went to youtube for x264 setting and used all of them.
-My usage for cpu when live sits at 34% currently (Which is normal for x264)
-Checked Task manager, non of my hard ware is maxing out
-Update all drivers
-Double checked I am on the Latest OBS update
-uninstalled and reinstalled OBS also tried moving it do different drives didnt seem to do anything
I have spent a full week trying to fix this issue and its the best that I can get it to go. I have searched and cannot seem to find and one else having this issue that i can find. Help will be greatly appreciated with this.
Additional info:
I am a multi-streamer to TikTok and Twitch, I have the aitum vertical plug in installed. Never caused an issue before. This issues happens no matter if i am only streaming to twitch or to both, but if i am streaming to both the issue stay the same no matter what, it will avg the same frame drops.
My build:
Single pc
-Update all drivers
Additional info:
